wheels i brought for my build are not spoked like abec fly wheels. this is due to me living in Australia, i couldn’t find any where to buy fly wheel clones except shipped from america, the postage for that is around $50. and genuine abec fly wheels are over $100 dollars. so i brought a set 76mm 83a solid wheels, they were cheap so i thought why not ($20 shipped). I need some advice and suggesting on drilling through the wheels to attach the pulley. and any suggestions on getting the pulley centred?.
Use a quality drill press. Without it its almost impossible to get them right.
I find it helps to make up a jig as well so that you get the holes the right spacing.
in practice I found that I only needed to drill 3 holes and that was enough.
How’s the durability of the wheels? I would imagine that the force of the screws on the fly wheels would slowly tear the wheel apart.
Never had one rip in 8 builds and over a year of daily riding.
I have never heard of that happening. In fact the only time I’ve seen a wheel come apart, and it was recently, it was a hub motor.
do you have any updated pictures if you ended up drilling the wheels
Thank you, Much appreciated, how did you do it and how did it hold up?
Made a jig with aluminium and a centring bolt that fits into the bearings and then just drilled the holes with my drill press, Just a note I really dont suggest going this without a drill press as you need the holes to be square.
is that pulley 3d printed?
Yep!
Hey, what are the specs of that 3D printed pulley? You mind sending the files over?
do a quick search in thingiverse
