A single case with fins are now available at our store https://shop.3dservisas.eu/collections/FocBox
Dream/perfect build.
Do I need to de-solder all the connections to fit it into the rubber grommets?
beautiful, like a work of art.
As we still havenât received new FocBoxâes from Enertion I canât tell you
Plus it is rubber, you can expand it ant push it over
@stimm for the phase wires some shoved through the grommet. But a few needed to have the heat shrink removed. I didnât have to de-solder any. Just used some . I didnât bother with the XT60 at the moment as Iâm not building just yet. But definitely need to de-solder that that grommet wonât stretch that much!
I might just cut one side of the grommet to slide them over. I guess I could seal it with some rubber weld stuff, but the tightness of the case will probably hold it all together.
Everything fits in the case. I soldered no wires from the connectors. The grommet fits around the xt60 as well. All grommets fit.
Bt module and RX outside of course. I disconnected the pins to the connectors, ran those through the grommets then reconnected the pins. Motor sensor wires kind of loop to the side then out of the box.
Oh yeah for sure thereâs no worries there at all - fits beautifully. I was talking about the servo connection for the reciever - all the connectors I have sit too high - have you used some sort of right angled one?
Servo is already soledered into PCB of focbox so shouldnât be an issue ?
Huh? Iâm talking about the 3 pin cable which connects the remote receiver to the FOCBOXâŚ
Oh nice - I hadnât realised people were shipping with that connection made. Thatâs gonna save a lot of fiddly soldering. Hopefully itâs not actually glued to the casing - taking the case off would be a bit of a pain.
No worries about that itâs easy as fuck do remove without damaging the cable
Yeah. It comes out of the focbox original case no problem.
Love the craftmanship!!! Will need some soon for my build.
This is so neat ! I am so stoke, it will play a huge role in increasing lifespan of the FOCBOX
@Kug3lis i have a question i wanât to mount it half inside and half outside my enclosure kind of like this
Do you think water and dust can go under the screws lid and get to the focbox ? Because the real utility for me is to put the fins side outside si it will really cool down because i have Carvon V4 so i heat very quickly
@Kug3lis So these are water proofed, and have better heat dissipation right? Sry but I donât have time to read the whole page for the moment
No, Yes, Okay
