As many have requested, today we started working on dual FocBox CNC machined case. Here are some early prototype pictures. This is only single case as the reference to figure out all the holes and design needed, later on, it will made into a dual case.
Thanks for @banjaxxed for providing Focbox as a reference for the design.
Single FocBox case without fins (26mm height) 30€ + shipping
Dual FocBox case with fins (31mm height) 50€ + shipping
Dual FocBox case without fins (26mm height) 40€ + shipping
We currently collecting pre-orders to know how much we would need to manufacture for the first batch. A pre-order will be you will have to pay 5€ for confirmation that you going to buy it. Then we finish you will get 5€ coupon code to deduce 5€ you paid from the final price.
Pre-order is needed so we could order required amount of material and save time on manufacture as we depend on 3rd party service for anodization.
@Blasto I dont know now correct number, but its calculated that it should enough with thermal conductive isolator to touch the alu with a bit of force.
@ElskerShadow It’s smallest possible otherwise you will have same opened design as original Focbox
Any way to machine a truck hanger / dual focbox holder / motor mount? So add a pivot and bushing seats and an axle with the two focboxes and screw holes for motors
That case looks great. Is there adequate clearance for the receiver wire plug? The case looks nice and low profile, but that plug sticks up a bit farther than the rest.
