Has anyone done this? I started with a 6355 single build, planning on making it a dual, but I regret going with the 6355 to start since I have 218mm hangers. Would I be able to run one 6355 and one 6374? Then ultimately switch over to two 6374’s?
yeah it works fine, probably the only thing I would say is that if you use DRV cookers dont use canbus, instead split the PWM wires.
Can you elaborate? Why no canbus?
What do you mean by drv cookers? 6374 motors?
well if you are using 2 different motors that will have different RPMs for any given throttle position I would think it best to keep the electronic parts as seperate as possible. while it *may work with canbus you would defininently want to disable any traction control feature.
DRV cookers = VESC
Ohhh. Okay. I’ll go with dual 6355s then.
why? go 6374
