Hi,
I have a LiFePo4 8s2p from Leiftech (LT1X 24v) and I want to replace it with a Li Ion Battery. (some says it is a 7s but there is definively 8x2 cells one mine)
Which one would be the best:
a 8s2p a little more powerfull than the original one, or a 6s3p for more range?
Or something else?
My set up is a dual single vesc with 2X 400KV motors.
I guess the answer is. you will cap your 4.20 at somewhere between 60-80k erpm and that would be your top speed. you can however go 6-8S if you want. higher S the better. However, you should be aware of the erpm limit behavior of VESC in general so you dont get jerked and fall at highspeed.
Ok I understand now.
I should limit the erpm to 60000 in vesc-tool to protect the vesc, but doing this will limit the interest to get a 7s or 8s instead of a 6s (no gain in speed).
I guess the best move would be to change the battery and the motors too.
Getting something with less KV, so I would be able to keep top speed with a 8s and gain some torque (actually there is no torque: you have to push start the board!)
Obviously there is more cells in the 6s3p, but you suggested there is range advantage to a 8S due to the voltage.
More voltage: more speed, but more range too?
Is there any advantage to go 8s2p over 6s3p in my case as I will limit the erpm to 60k?
Thanks.
8s2p gives more torque, but you basically have half the range than if you went 6s3p, and stayed at the same amps. The sag at 8s2p is really gonna be bad, and at some point (probably 25%) you’ll just stop riding because it’s either too slow, or it’s making weird sounds.
I think 6s3p is the better choice, especially with your current part configuration. If you want to go crazy a 7s4p would give you very satisfactory performance based on what you had previously
