I’m running dual VESCs in BLDC over canbus. On uphill climbs, the skateboard stops when it reaches 70.2C. This happens consistently. I used real-time data monitoring and observed this. My FET cutout start is at 85C and ends 100C. Also, I’ve observed no correlation between my motor temp cutout nor voltage dropping below the min (30V) with the skateboard cutting out.
Has anyone had this type of experience? Why’s the VESCS cutting out at 70.2C when I set it to cut out at 85C? Thank you.
No faults. It seems like the VESC thinks the fets are at 85C and shuts down the board even when real time data shows they’re only at 70C. Either the fet cutout reading is not working right or the temp monitor on real time data isn’t accurate.
Here are my general settings and temp settings. I meant 80C for the FET cutout start, not 85C. The board slows down to a crawl uphill rather than abruptly cut out. That was yesterday. Then today (92F), on a flat, rectangular, 0.5 mile course, my 210lb buddy rode it hard. It crawled to a stop after four laps. I couldn’t measure the real time data, but the behavior was very similar to the one where I was climbing hills. I think the VESC thinks its at 80C when it’s really at 70C, but I can’t confirm or correct that. Thanks all.
well ok, i live in mild german climate. but i never even got close even with my single 6s drive. guess my weight does give me a hughe advantage.
@PDXroses are you running vesc4.12 or focboxes? havnt even thought about that angle.
alright, yes those things have no direct fet cooling, making them run hot faster. there are some How to heatsink vesc in this forum or just buy one from flipsky over banggood or ebay. I have one and it saves alot of time, but if you like going DIY there are some ways to tune those things^^
You’re awesome. Thank you. Will the heat sinks help if there is no way for the air to ventilate and is trapped inside the plastic? Won’t it just delay the cutout by a few minutes?
And my broader question is why the board is cutting out at 70C when I set the FET temp cutout start at 80C. This right here is a mystery.
maybe it isnt even your fets but your battery. what do you have?
btw here is the link. and yes it just delays the heating. you could take a aluminium/copper plate/pipe and lead it out of the enclosure and have at the outside some cooling fins.
or if you are lazy^^
My point was he’s across the pond for us over in the US… and he might be right now, but I just installed the case and will be testing tomorrow after work… it’s supposed to be 34° tomorrow so let’s see how well the board handles the heat now haha
