hey guys im building an eboaed for the second time but thats the first time i use VESCES
i dont know if thats a problem or not but is that okay if i use different firmwares of my vesces ?
i mean i have one now the vesc 2.18 firmware
can i use it an use other one which is 4,12 firmware with canbus connecter ?
I bet you could run different firmware if you didn’t want to update. Just run split ppm and set them both up individually.
I currently have a vesc 4.11 and a 4.12 that I am running on a dual.
4.12 is the hardware and 2.18 is the firmware. Plug them in and check. They may actually be the same.
If they are different, and you need to run canbus, just update them. It is really easy.
