@Ixf nice links! How is waterproofing on them? I have some GoPro bags but they only splash proof. Water is coming through the zip lock.
i would say splash proof. I ride them in the rain without issues but I wonāt go running into puddles. Great things about these bags though is the padding. no worries about vibration at all and zippers means if i need a ventā¦ just open them
SOOOO Sexy!
They look pretty clean and compact as well. Like it a lot. Good to know from where to get them.
As we here all together to all who use lipos, how warm does your lipos get after a hard ride, approximately? Just interested but canāt compare by my own as I have only one the same brand of lipos on all my boards for now.
Thread makes me jealous
I have one of the wooden decks left I can sent you one Matrix2 truck you already have, gears you make by your own things getting together slowly
Stop trying to force it
Should have bought the mbs truck with metal base plate thoughā¦
You can always upgrade later. Or just sent it back and ask for replacement with metal base plate easy peasy
We slowly overtaking this place soon it will be called e-mtb.builders forum
Not quite done with mine yet, thereās still a few more things I need to do like solder some shit and attatch the chain, but hereās a sneak peek:
Canāt wait!!!
How is your wire Mgmt looking inside with those giant 22ah lipos. For me itās a Russian roulette
Stuffed a sensor on side of 10ah tattu 12s lipo set up. It not terrible, but could be better. This is on that ridiculous pintail I was picking fights with earlier.
He goes anywhere I do on a trampa.
I need to install a small temp sensor I have at home as well, just need batteries for it. If I touch the packs directly after a hard ride I would say 35-40 degree minimum. As i use only 5Ah packs in 1P there is a lot of stress on them, so itās to be expected that hight temperature. Nice to have a comparison to other packs. Thx for sharing your info!
I did it because I watched a YouTube video about why Tesla packs were king of the roost. They stressed pack temps.
I swore my buddy (Iām basically his mechanic) was going to wreck his set of lipos unless I turned down the amps. I was guessing close to 100f. I guess Iām a bad judge of temp. Hands were always wind chilled when I pulled his lipos out after a ride to check.
6380 170KV motors. GRAPHENE 6000MAH bats. Dual foc boxes
