Wow! Do you reccomend the deck?
Does anyone here use foot hooks instead of straps?
At the WheelsGames 2018, one was in hooks, and you can really turn and raise the front easily (a pro mountainboard rider also try, and it donāt work. 90Ā° and 180Ā° turn was not easy, the rider have to get off the board to turn it the right way ā¦) :
If youāre lightweight or will reinforced it yes.
At 1st it was tooooo flex for me, even for my GF :
Haha thanks!
I got more pics here : and here :
Foot hooks like the freeboard bindings are good for carving, but as soon as you get into harder terrain bindings are definitely better.
- MBS Comp 95 / F5 bindings / Matrix II / Rockstar II Dewedged rear - 5Ā°, yellow-front /orange-rear blocks
- Dual FOCBOX @ 10s & dual ESCapes @ 12s (soon) Plan is to mount both, then swap phase wires and swap battery from 10s to 12s whenever I want.
- 10s2p 16Ah Zippy Lipo (4x 5s 8Ah) 592Wh (soon) 12s1p 6Ah Graphene or 12s1p 8Ah Nano-tech
- E-Toxx 5:1 Helical mini gear drive w/extended axles @idea V.2 motor mount used as front bumper for now
- Build Kit Boards 6374 190kv motors
- Mini remote w/ dual receivers
Goal is to be able to run 10s or 12s and utilize my collection of Lipos if I want to go for extra range, speed or both. Front motor mount cage will stay in case I decide to try 4wd with belts up front for a hybrid belt/gear drive system. For now, it makes a nice front bumper/light mount with some heavy duty foam I got from a small laptop box.
Also have 9" & 10" Harbor Freight tires and old MBS tri-spoke hubs that will be used on a monster 4wd/golf board at some point.
Then there is the lightweight, balanced jumping board I want to make with top & center mounted batteries and ESCās, dual diagonal drive, and either 8" MBS wheels or 6" @psychotiller Six Shooters on 9.5mm axle trucks.
- MBS Core 94
- Idea MBS ATS 12 mount
- 2x Turnigy Aerodrive SK3 - 6374-149KV unsensored
- 4x ZIPPY Flightmax 8000mAh 3S1P 30C Lipo
- 2x ESCape
- currently swapped for Cheap FOCers
- AVIO remote
- DAVEga (obviously)
- Very sophisticated battery/ESC enclosure that I have designed myself. Took months and months of research and development and involved substantial manufacturing cost.
Soooo nice builds here, man somehow we have to shred all together
MBS Comp 95
F5 Binding
Vesc6
Dymond 6374-200kv
Sony VTC6- 12S4P
Etoxx Maxi Gear Drive HELICAL - 1:6.25 Gearing
AS5047 Magnetic Encoder Inside
Just put my MTB together, any advice?
Very nice.
Iām curious as to what the encoder does? Been hearing the word being thrown around but didnāt really look to much into it
I just asked the same question so Iāll forward the answer along:
Itās like a much more precise hall sensor.
Have you looked into pulleys for the trispokes? The second hand board I have has trispokes and my vision for it involves y The biggest tires I can find. Iāve got a cad model Iāll be printing soon but any advice would be appreciated
Probably not the most practical or neatest box solutions but hey, i can always call it a prototype!
HS11 17 ply
Infinity front truck and vertigo in the back
Superstar rims
8" primo alphas
2x vesc 6
2x 6384 130KV APS motors
Etoxx mini gear drives
12s9p 30Q pack (around 1150 WH)
As @venom121212 said itās a replacement for your hall sensors. You place a magnet on your motor shaft and in a defined distance a magnetic sensor pcb is placed. The sensor than can very precisely detect the exact position of your motor. Boosted use a similar encoder on there boards.
There is not much information about it in here, but you could have a look here
Or here
If you interested in reading about it @Linny
Thatās basically what I tell myself and others, and helps me justify putting all my safety gear on for each ride. I remind myself that these vehicles are hand built DIY experimental beasts and Iām essentially a test pilot on every ride, so Iād better be ready for something to go wrong and be able to crash land safely. And since Iām constantly changing, tweaking, fixing something almost everytime, almost every ride is a test ride of a new configuration, and I am in fact, a test pilot.
I have some 65 tooth aluminum pulleys that I got from Aliexpress. They call them scooter pulleys, but they were actually first sold to me by @kaly way back in the day. Iāll take some pics and find a link for you after work.
