Elephant - Evolve evolved: an upgraded clone
i guess that;s where the fun is :laughing:
@bigdog @MrDGOrman Check his other build, guys : https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/optimized/3X/9/2/929ebdf47c45bc837e0abb9f1747bb2f2f9c5025_1_399x500.jpg
All infos here :
French do it better.
is-len-really-leaving-dwts-ftr
thanks guys :blush:
I don’t have the total budget, but should be the same price as a bamboo GT … or less :slight_smile:
AT mode :slight_smile:
IMG_20180809_163015_Bokeh_2IMG_20180809_173052_996IMG_20180809_162941
Very nice setup mate! I am busy with a similar build right now. May i ask which motor pulleys you are using (are those from APS?) ? Because it seems most pulleys touch the wheel when in AT mode. I just ordered motor pulleys without overhang to make sure it will fit the AT setup but when looking at your pics it seems that there is enough clearance eventhough you’ve used pulleys with overhang…And what belt size do you use?
Hi, I uses 15 mm pulley, from unikboards, but should be the same as APS.
