So I’m in process of building an eMTB using following:
*MBS Atom 95x board *SPACE Cell battery + enclosure from Enertion dual belt motor *Dual VESC-x 4.12 *switched from using canbus to Y-connection to receiver for enertion nano remote *front & rear Mountainboard trucks kit from Amazon/L-faster, includes dual motors with the following specs: Model: N6374 Voltage: 36 Volt Output: 2800 Watt Rotate: 230KV Rated Current: 120A
So, I know it’s not gonna be up to par w the trampa builds I’ve seen on here, so please spare me those kinds of comments.
Questions I have are: *should I run it in FOC since motors are sensored, or just stick w BLDC *are 230Kv motors too high, especially since I’m about 220lbs? *if I do BLDC anyway to stop the jittering/stuttering of motors on startup from stop, or avoid having to push start? *what setting in BLDC TOOL do you recommend? Currently have motor max set at 50, should I go to 60?
Thanks in advance!
