So close to finishing my emtb project. I just have a big problem
Itās about 1/2ā gap
What should I do ? Was thinking thick gaskets but donāt think I could find something that thick. Also thought about even applying some sort of wedges on my board where the enclosure will sit. Iām kinda helpless atm does anyone have better idea then what I came up with ??
The batteryās too tall for the enclosure
What about a little bit of silicone?
Edit: As far as I know there is even some black siliconeā¦
You carry any enclosure thatās 1 1/2ā tall and 2ā 2/16ā long ?
I dontā¦Is that pack double stacked? A single flat row of cells is 3/4" tall. Double stack would be 1.5"
Double stack 12s6p
What mounts you using on those trampa trucks? Edit: dope I mean MBS trucksā¦
I canāt see in your picture but does your enclosure come with gasket?
If you canāt find a enclosure to fit or make one yourself, and you donāt care about losing Flex. You could build up the deck by using thin slats of wood and some kind of epoxy/polyurethane sealer⦠seems like more work than just making an enclosure but, it could work.
@ethel Iām using MBS matrix I I believe their called and the mounts that I have will be @Rithblu
@Skunk yea not worry for flex since my pack is non flexi, so I maybe have to do something like that. I was thinking of putting thin strips of wood where the enclosure will sit cause a raise for the enclosure
A gasket around the enclosure may help
Like some 1/2ā tall gasket. Searching eBay and Amazon right now. Could even probably double stack the gaskets if I canāt find the size I need
How did you double stack it???
Wouldnāt that be triple stack
Donāt think so. Once folded itās double stack, unless Iām wrong
Oh. Thatās before. I see. Derp derp
Hahah you had me second guessing myself there for a moment
What deck is that one? If itās the MBS it will flex, this could be very dangerous for a non flexible battery pack.
Please upload pictures of your battery build, but as I see it Iām very concerned
@Eboosted Itās a ebay mountain board deck thatās 10ply thatās stiff with no type of flex
Hereās the photo of my pack setup
Pretty much like my 10s4p setup Iām riding now just this time 12s6p
Please give any advice
I would love your inputs
I have a hard time believing the deck has no flex at all, all mtbs have flex even the 10ply ones. Hop on the board with no electronics mounted and jump on the center, you might get a closer insight and decide if you need to rework that battery pack.
Remember you need fish paper between p-groups thatās the main cause of fire
