Looking for a solid esc for a brushed 800w motor, thanks in advance!
What voltage is the battery charger?
If the charger is 42V then a single (not dual motor) VESC rated at 60V will drive it. One of the many 60V ones on the market.
If it’s actually a 36V battery (likely lead-acid) with a 36V charger, and that’s not just ebike jive, then a Mamba XLX2 will work well, but be expensive.
You have to be careful because sometimes “36V” is a voltage measurement, and sometimes it’s simply a name.
Thanks! It is a 42V rated charger - could you recommend a couple that are on the market?
I have a high-performance brushless motor high-power dual-drive controller based on ODrive. Does anyone need it?
