While looking through some pages i found a nice ESC that maybe suits some builds of members here… calling @MoeStooge for the next generation raceboard haha
It is called the MGM ESC TMM 25063-3 X2–SERIES | 360A |
- Max. peak current (5 Sek.): 360 A
- Max. continuous current (for full throttle): 250 A
- Operating voltage: 12 - 63 V
- Weight without power conductors: 300g
- Servocable cross-section: 0,25qmm
- Length of the servocable: 190mm
- Max RPMs: 250.000
- Number of regulation steps: 2048
- Motor PWM frequency: 8 - 32 kHz
- On-state switch (FETs) resistance at 25 °C: 2 × 0.8 mW
- Available BEC / OPTO versions: Opto
Still, don’t know about brakes or anything… maybe someone with a lot of moniez test one
Found some more informations:
- Empty batt. behaviour - instant motor cut-off
- Setting of the range of neutral zone
- Possibility of switching reversible controller into “one-way” mode
- Reversible controller (both-way mode)
- Bidirectional “both-way” mode
- ACL - Automatic Current Limiting
- ACR - Automatic Current Reduce
- Temperature fuse of the controller
- Current fuse of the controller
- False-start protection
- Masking of interference
- Software reversal of rotation
- Empty batt. behaviour - motor power reduction
- Adjustable deceleration speed
- Adjustable acceleration speed
- External signalization of important states
- Possibility of connecting plane position lights and flashing lights
- Active free-wheeling circuit ON / OFF
- Possibility of automatic setting of throttle limits
- Possibility of manually set timing
- Automatically set timing
- Manually set type of cells
- Possibility of manually set number of cells
- Possibility of automatic setting of cut off voltage
- Possibility of setting switching off voltage
- Possibility of setting current limits
- Possibility of setting RPM limits
- Possibility of motor temperature measuring
- Possibility of cells temperature measuring
- Very high resistance against overloading
- Plug and Play (functional immediately without the need for additional programming)
- ICS-2 connector - super-fast PC connection link
- Programming using PC
- Reading-out of data from the controller using PC
- Software updates available through internet
- Telemetry (back data transfer)
- Real time monitoring with pc or other device (for pro series only)
- Internal Data Logger (data recorder)
- Possibility of design with ON/OFF switch (connected safely)
- Possibility of WR version (full protection against water)
- Possibility of WP version (increased protection against water)
- Possibility of design with external heatsinks + FAN
- Possibility of design with water-cooled heatsinks
- Compatible with all types of feeding cells
