Thank you for the pic, I’ll try that
Hey guys sorry for disappear for so long.
The populated PCBs are ready and in the UK and were meant to reach me last Monday but they got stuck in customs (arrrgg). I need to provide customs with more info. I apologise for the huge delay. I will let you know when I have updates.
Oh man. I hate customs so much.
thought I’d post back about my first batch units. Still works perfect. hope they soon find a way to implement BT onboard tho so we can have flashing and everything throug that. I don’t have the USB sticking out and my BT dongle doesn’t support FW loading/pc connection so I only access it by the app now.
+1, but On-board BT means at least implementing at least rudimentary authentication, right?
How should these sensor wires be arranged. Tried flipping the wires but same error
Maytech Sensor Cable
Extension adapter
put the black wire where the green one is and connect it to the maytech black put the green wire where the orange one is and connect it to the maytech green put the orange wire where the yellow one is and connect it to the maytech orange let the white wire in place and connect it to the maytech brown put the yellow wire where the red one is and connect it to the maytech yellow put the red wire where the black one is and connect it to the maytech red.
Then you should be good I think…
Nailed it…
I need to be high to understand that. Wait a minute i’ll go fetch some dope.
No dice… I also remembered that this ESCape is from the 1st batch and the sensors are reversed so I also tried reversing the wires but still unsuccessful…
But let me see if I got this right…
On the Maytech Sensor:
Red = 5v Yellow = Temp Orange = Phase Brown = Phase Brown = Phase Black = GND
Does that look right?
nope I think I remember green to be temp so maybe I mixed something up here. The thing is my cable works and I figured out how to set it up by watching this schematic so maybe it will be more helpful.
Another thing is; the labelling on the ESCape is correct, even if the connector is reverted compared to other vescs, so trust the labelling.
phase wires doesn’t matter so basically if you get red/black correct according to the escapes labeling then you can just throw on brown/orange on the hall connections and you should be good to go. Make sure you select 5V on the switch if your sensors are 5V.
Any updates on this?
I think and somewhat hope he maybe finishing and testing units by now or soon at least, but its really depending on what that customs thing was about and whether its been solved or is ongoing still.
I personally don’t mind the waiting as i expected it but the not knowing about the customs problem outcome/situation at this time is slightly disconcerting.
Yea I personally don’t mind too much about the waiting, just that the fact that there hasn’t been any updates for 16 days has gotten me worried just a little bit
Don’t worry guys I send enclosures to @stewii three days ago so I believe everything is close to be finalized
Do you guys plan another run ?
