Here’s a little build thread of my latest unfinished project. I wanted to build a compact board that I can easily take with me as a carry on when traveling. Im still trying to figure out a way make the battery easily removable for TSA check but will likely end doing an ABS battery housing held with 6 bolts and bring tools with me to reinstall the housing.
-JACOB HUB MOTORS I decided to dye the urethane black using rit dye and vinegar and also installed set screws to hold the torque. I ran the motor wires through the base plate for a stealth look.
-SPACECELL I bought a used space cell awhile back that had been modified for his build. I made a new housing for the electronics and recovered the battery in ABS shrink tube. Now I just have to make a nice dumby manufacture sticker with 80wh so TSA doesn’t bother.
-PARIS 185MM FRONT TRUCK because these motors have an offset I bought a larger front truck. Unfortunitely I could only find one in silver so I will likely powder coat or paint black.
-PARIS 165MM REAR TRUCK
-EBAY 83MM BLACK FLYWHEELS
-27IN BLANK DECK
-1/16IN ABS SHEET BATTERY HOUSING
Waiting on -2 VESC because this deck is so small I will be mounting both vesc sideways -JACOB BOY BETA CONNECT REMOTE
