The ESC will work great for non electric skateboard things. I personally would only use a VESC on an esk8 though.
All the places that said they where sub part where boat and car forums.
Oh I didn’t know about that. It worked on my e-board as long as I didn’t push it too hard (that’s when it failed & they sent me a new one). After that I got high-output VESCs and never looked back. If no one wants it I was planning on hooking it up to one of my old RC cars.
I got one the other on the way…then cause I’m an ass ordered this one to see https://www.ebay.com/ulk/itm/262351695324 But I fear this will take forever to get here
Stuff seems to pop daily
Honestly I wish the ntm 270 was stocked they are the best. So durable and cheap
These are pretty darn cheap compared to the NTMs
Yea but does the quality match? That’s what I’m relying on you for haha let me know please
Will do mate …/
Still looking for a motor preferably above 200kv just motors though.
check this out and let me know what you think
I took a look at it…odd size shaft… But prob could get the size pully some place…there are plenty of cheap 63mm with 10mm shaft … Just need to pully with the 10mm bore seems everyone has 8mm
Check ebay, that’s where I got mine. Works great and super cheap: http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X10+mm+timing+belt+pulley+htd.TRS0&_nkw=10+mm+timing+belt+pulley+htd&_sacat=0
I am currently using the 15 tooth pulley with 10mm bore on one of my longboards with no keyway. The grub screws that came on it are large enough diameter to handle the stress.
All I did was take a dremmel and grind some flats/divots where the grub screw contacts on the motor shaft.
I am 230 lbs and even on a single motor setup with hills I have never had an issue.
Ok cool good to know … You sexy beast
nah i can easily make one
im building a 10s4p pack. Two of TB’s 12s ESC’s and a bms. Whatcha got for that?
SOLD!
Here are some pics of the torqueboard’s 12s sensored esc (with programming car), 6s esc, and Enertion 245kv motor.
The TB esc works great, I just have two VESC’s and don’t need it. For those of you who PM’d me(about any of the items), If the guy with the highest bid doesn’t back out, and if no one wants to go higher than him, then it is technically already sold- that said, I didn’t have any pics before so I’m still open for offers.
The 6s esc is in rough condition, but works- it has no servo connector, and the power switch has been cut off and re-purposed. If you wire the two red wires together the ESC will just turn on as soon as it’s plugged in. If you buy it, and it gives you troubles within the first week or so, I’m happy to refund you whatever you paid for it.
The Enertion 50mm 245kv motor works fine, but has definitely had some miles put on it.
I’m selling a bunch of stuff including a Jet Spud Deck, Tacon 160 Motor, LifePo4 Batteries and Lipo / LifePo4 Charger + power supply. Probably should’ve just posted it in here but I gave them their own topic:
