Just got my new motor, and noticed the shaft is really short so none of my current mounts will work since it makes the pulley go over the shaft (Leaves a 1mm hole or larger)
I’m on a bit of a budget so I need a semi cheap one, and maybe also a new pulley for it.
I was thinking about getting what they offer but seems a bit too expensive for me for the time being. (Would end up at 120 - 130 or so)
hmm ok… how about flipping your pulley? So that the small part sinks into your motor mount?
If it doesn´t fit, you can file out a bit material to make it fit.
Other than that
If you don’t want to glue things I would recommend a Spann(zug)hülse (clamping sleeve?).
You would need to find a possibility to widen the inner diameter of your pulley to 14mm.
This one has an inner diameter of 8mm and outer is 14mm.
