No - nothing. Problem is that I am welding the mount. once it is mounted I wont be able to easily adjust that range so I was hoping to start with the right width pulley. Will see if they know of anywhere I can get them.
Failing that I might just ditch the pulley from the GB and go 15mm and eventually get a 15mm wheel pulley to match and upgrade the belts then.
Just looking for one that would fit the belts I have and I am working with a small tolerance at this belt length where I think the extra 3mm might mean that the edge of the wheel pulley may catch the outer edge of the wheel. Need to have a mock up of this.
