Price €250 + shipping Total cost new was around €320.
Have for sale a Never Summer Reaper 2016 deck with a eBoosted enclosure made specially to fit the shape and lines of the 2016 Reaper. In almost as good as new condition.
Only damage to the board is 4 threaded inserts have been screwed in to attach the enclosure. Although If you’re going to be using it as an eskate then I wouldn’t really consider that damage. Have also attached a rubber gasket around the bottom for the enclosure to rest on to provide some protection. Can be removed with no damage to the board. Board was never actually ridden, only built up then everything was replaced.
Info on the enclosure from the eBoosted enclosure thread
Enclosure has 4 holes drilled for bolts to attach to the deck and a hole on one side for a power switch and a hole on the other side for a charging port. There is also a small chip by the charge port that you can’t see from drilling the hole.
