Hello, This is my first post/ first build, though I’ve been a long time lurker. My carbon gt’s bms went bad last fall and evolve wouldn’t let me buy a new one or attempt to repair it because it has a battery mod. I decided to gut it and diy. I kept the deck, battery (made by @longhairedboy ), and motors.
Specs–> Battery - 10s4p 30qs: Bms - bestech PCM HCX-D596 (80 amp discharg): Motor controllers - duel focboxes (connected via canbus): Motors - stock evolve (150 kv?), Controller - gt2b / 3d printed enclosure, Gearing - stock evolve 15/ 32, Wheels- abec 97s
I’m using foc mode and set battery amps to 30, motor amps to 60. My issue is with the top speed. I’m only getting to 19 or 20 mph. I know foc mode causes me to lose some speed, but it’s so smooth and quiet. Should i switch to bldc mode to get my desired 25-27 mph? Also, my bluetooth won’t connect while I’m riding. Any tips are appreciated, and thank you all for the invaluable knowledge I’ve gained from this forum.
