The gen2 has this silver stuff under all of this rubber. Was wondering if it was safe to route through it to fit a bigger battery. Don’t want to go with a spacer. Want it to be slim.
Also what is this? It comes off the bms
The silver is aluminum tape to increase antenna reception for the remote.
The white wires and aquare are a thermistor that monitors pack temperature.
I’d add the aluminum tape back after routing.
What happens If I don’t add the aluminium tape after routing?
You have worse antenna reception
Put the thermistor inside the pack.
