Wheel shields go directly on the wheels but they aren’t meant for wheels larger than 80 mm. These do look cool though. I don’t think wheel bite should be an issue cause these sit pretty high.
Yup that’s what is written in the description. Since this seems to be the only alternative to wheel shields ,the question is can these be used with long nosed decks?
The problem is that they are made exclusively for LDP boards which has the mounting holes closer to the front end. So in this regard only true LDP boards like some of those manufactured by 1166 Longboards, Antidote, Rocket, Cobo, Alan Lani or Subsonic could use them because their shape. See…
Thanks. I spoke to the manufacturer and they gave me the dimensions for these.
It’s 7.5 cm going to 8cm on the sides. Now I just need to find out how wide the nose of my subsonic deck is and if it fits this should be perfect. If not, I might explore mounting this underneath the deck rather than over it.
