Hi guys, as many people were asking about smaller wheels like (125mm) for direct drive, after spending some time on the design we finally have something to offer.
Some initial specs:
~90mm diameter of case
3:1 gear ratio
Outer gear style
Motor gear in aluminium 7075 T6 coated with a hard surface or something similar don’t know the name.
Wheel gear machined from POM plastic.
Should fit mini hanger from Trampa with small filing one surface.
I don’t know what it is as I didn’t asked, but you can see in my inner gear pictures how it’s different color, after riding not a single scratch on the surfice
Sorry @Kug3lis I’ve change the title, I think gears drive and direct drive are two different system and since your system is base upon a reduction it can’t be call direct drive
My point was just to name thing for what they are and not what we wish they are. And start educating people on real term, I know Jenso Call is drive “Direct Drive” but it isn’t right neither, and now when you talk about hub everyone is confuse.
Oh man. Just when I was about to spend my money elsewhere. I guess I’m back to a holding pattern for a while. Just as well my battery build is taking longer than expected.
guys coming from hubs want a carvon to be a direct drive… guys coming from belts and chains want a gear directly driving the wheel to be a direct drive.
And wikipedia is hardly “evidence” the page was edited a few weeks ago and not that long ago I thought I remembered reading the same page and it said something else…
Im pretty sure that direct drive means direct transfer of the motor revs.
Note NO gearbox.
By that definition carvon IS a direct drive, as it is just a hubmotor…
I’d say carvon is a direct drive and not a hub-motor as the motor is not the wheel hub…
and I had previously asked Jenso about why he called his gear box a direct drive and he flicked me up a page referencing his perspective… And I respect him enough to move on.
At this point we can argue semantics of drive systems or if it should be eMTB or… it don’t really matter unless you are a keyboard warrior looking for conflict (no dis-respect Dan, just making a point).
