Is there a gasket on the core to keep from debris entering?
What are the draw backs of a 10mm gear?
I suppose this fits dual 6380 with the 240 hanger
Is the cover POM or 3D printed?
There is V-ring same as on Mini
6380 would fit on 240 but I think they would be bit too much if ran high currents but it depends.
Cover is the same plastic used in FatBoy SS impact/noise reduction plastic.
Shouldn’t be I just updated as in reality Mini gear width is 14mm. So 4mm less will not have much different Also don’t forget this is on urethane in worst case you will slide which will reduce stress on teeth compared to pneumatics.
Also on the side it should be even more silent compared to mini as contact area minimizes so I wouldn’t be surprised that it will be the same noise as belt drive
