I also found it locally. Paid $15. Found it at a hardware store that sold car parts, scooter parts and other random overpriced shit from China.
yea most of the time its those small mom and pops shops that carry the hard to find random stuff/parts you need haha. Found some tiny grub screws I needed for a motor pulley back then after going to countless hardware storesā¦
Hi everyone!
Received my drive today and it feels and looks awesome! Money really well spent
Only issue iām having, is that I canāt press my flywheel clones on the wheel pulley. Think itās because the core is a bit thicker than normal abec 11 flywheels. Could probably be fixed with a bit of drilling. Just thought iād let everyone know.
Anyways, awesome work @3DServisas & @Kug3lis ! Keep up the good work!
Wheel hub adapters are hard fit. You need to hard press them in so no movement.
I definitely didnāt press very hard. Will try that. Just looks like there is not enough room for the core when comparing the wheel adapter and wheel core with a screw.
Tried pressing but it didnāt go in. Iām afraid if I press any harder I will break something. This is what I mean with the screw.
Is this a 107mm flywheel ? It not hard press on the Kegel core I have test. Just normal easy fit.
Itās 90mm flywheel CLONES. Clones core are a bit thicker than Abec 11 flywheels
ha ok ! You want to ride with 90mm ? If I was in the flat perfect Paris street I could make a test with 90mm too, but where Iām now absolutely no way
You need to drill them out or buy genuine wheels with smaller spokes.
90mm no way. I was planning to use 100mm MBS wheels (big spoke) but might change to 107mm abec 11 (smaller spoke).
Was just in the Websiteā¦ whenās the next round? Or can I snag a set from current batch?
You can buy right now .Sending next day
By chance mini also in stock ? Canāt deckde between the two
Out of stock Mini .
Used the Nano on the track with dual 6374 and 80A battery, alot of different riders and weight did try it. Still look new after!
Any video?
What grease is that?
Yes 2 newest videos on the Instagram www.instagram.com/Bioboards_eskate
The grease is a copy of molykote g67
Sounds great!
Are you using the printmaster grease?
