~50km /h 10char
How did you use the calc to find out? What values did you put in on the drive train in the calc?
10 and 26 10char
Hi sir!
Whatās the estimated delivery time? Do you offer a Kit including the ecaliber?
Thanks
Truck, motor donāt include in the kit! Shipping will be the end of January .
Just got It
I have never mounted this kind of things. Have you written somewhere a useless morons guide? I donāt know where to cut the motors axles, what kind of grease is recommended etcā¦
https://www.ifixit.com/User/2822263/Aurimas+Niekis
None for nano but itās pretty similar?
EDIT retracted incorrect grease
Which motors are you using? I had to cut motor shaft quite a bit so that the motor spur gear didnāt hit the cover.
Recommend and Molykote Multilub Grease
Not Molykote G27 , true brand Molykote G-67
Yeah like they said G-67 not G27. But I couldnāt find it anywhere in the US. But if you decide to buy it from EU. I split it with you if you want.
USA equivalent MOLYKOTEā¢ G-4700
Of crap. Didnāt realize that was the same thing. Thanks a bunch!
Not quite same, G-67 is NLGI#1, G-4700 is NLGI#2 (viscosity rating, larger number is thicker)
Also G-67 is not synthetic, G4700 is synth. Usually synthetic seems safer for plastic/rubber.
Hm and G4700 has MoS2 which is great for metal but usually not good for plastics (but maybe okay with POM?)
Eskating.eu 6374 sealed
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.es%2Fulk%2Fitm%2F263895015150
That one? And the recommended length of the axle?
Iāll check with experts what is the US eqivalent for Molycote G-67 tomorrow and let you know .
Recommends gear oil
Molykote G-67
Molykote G-1067
Molykote G-1056
Molykote G-1057
