ok bro so you say 300a with external cooling… more than your heatsink?
I ask as i’m building a board now with 2 x 148a motors (8s), data logs show over 100a a piece constant.
Constant for how long 10-30min? You can run with this block for pulses over 1min no problem it will get warm but not that hot. With over 100A constant for like 10-20min you will need external cooling. But for normal esk8 rides where you get impulses of 100-300A for like 30s it will be enough
ok
so just a fan like my speed controllers?
might stick to 8mm anti-spark connectors…
thanks bro, block of aluminium looks cool, love the saw marks on the ends
I highly doubt that any of you guys will run AWG0 for high current so first your wires will heat up pretty nicely. If you will be able to show me constant at least 1 min on currents higher than 100A otherwise like I said its normal esk8 loads don’t need much cooling as those are not longer than minute long or etc
So it doesn’t include the actual push button right? Do you have one you recommend?
Maybe you can make explicit what this means to you. I’m inferring 100a from the pack for 1min at a time?
The people intetsted are probably the power users and “normal” means different things to different people.
What he said, and some of us are shameless hardware-junkies!
I do like the headroom in this design
In my opinion, “normal esk8 loads” means 8kW peak for up to 1 minute and 500W continuous
At least, that’s what it means to me…
Yeah that’s right I mean you can do peak 15kW if you want and you wires, connectors will hold it for sure and do like 2kW constant otherwise you will need actively cool it down
I am riding myself 10kW setup and never even seen more than 2kW peak per motor (I am running 5:1 high torque setup so current is way higher than normal setups)
Any momentary button will work, even shortening the wires like in movies
Is it possible to order one of these with everything hooked up for an extra fee? Push button, fuse, LED, etc…
Sorry this is DIY kit… Everyone uses different configuration and adapt to their own needs…
Ok no worries. Do you have any left in stock?
Yes there is some left, but I can’t guarantee it will be in stock several days later…
https://shop.3dservisas.eu/collections/fatboy/products/fatboy-sparky-switch-v1-0
Still available Also working on smaller version for not so hard core riders
I’m considering getting this but I need a good bms for it
You can use this wired around your BMS like a loopkey if you want to
Ohhhh no I meant I haven’t been able to find a good bms that I can use with it , tbh I’m overthinking it
For 10S, a bestech D190 is good but I’m sure there are better (smaller) ones out there
That big one is super reliable but the size of it made it a tad impracticle for my application
