just search vesc beginner guide on the search bar.
Literally search whatever comes to mind
Things I’ve typed:
“Motor amps for peak performance”
“battery max”
“will I blow my vesc”
whatever is on your mind, then read read read and ask questions. Lots of knowledgeable guys you can run to on here. the higher their reading time the more helpful they likely are. People with multiple build ++++. Trusted Vendors +++
additionally, if it helps, I ran my hubs with FOC but it was sensorless… could be a reason your chip ate it…
also 53 for maximum input voltage isnt proper, its supposed to be 57… I cant explain why but Ive seen multiple people who say its not a good setting to touch…
maybe next time you setup the vesc go small and work your way up ( first dial bldc settings in, make sure it works, then move on to FOC )
make sure you change not only the stuff in the FOC tab but also under the app configuration make sure you take care of all the stuff like control mode and what not
I try my best good luck man
feel free to pm with any questions
Did you check the 5v rail? is there anything getting hot on the board (e.g. the TVS diode near the ppm input), that rail should be close to 5v +/- 0,1v. above or below that the drv will give errors, but USB still works (uC works of 3v3)
There not so much solution apart avoid using more than 8S voltage I would say (for a reliable VESC I mean, there is always someone who succeeded running a couple of seconds a 80100 with 13S in FOC with Maytech VESC…).
I would advice you to switch to BLDC mode with those VESC.
maybe stick with dual focboxes and put them in @Kug3lis s case? It seems to do a good job… I havnt recieved mine yet though. Im just relaying what ive been told
