FAULT_CODE_UNDER_VOLTAGE (VESC problem)
It’s a “smartbms”(at least looks like one) they’re weird af lol
Some of them go in a protection mode, where you´re not able to do something. They activate it to keep you from starting a fire. Wire it off, check your cells, charge them a bit and try to connect them again and see how things go.
Have you try to bypass something on the BMS ?
And is the BMS made for LIPO?
How do I charge?
What high amp BMS should I get?
I have Velcro under them. They aren’t moving anywhere. I’ll be sure to protect them better in the future. Also, who doesn’t love a bit of magic smoke every now and again
with some other lipo charger, like an imax b6 or something.
lipos like to be coated, don´t just glue them in place naked, that´s kinky :no_good_woman:
coated with what?
I believe he meant wrapped This is how I repacked a lipo https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/3511
heatshrink and then something cushy, like a neopren sheet to avoid vibrations
