I was test riding my DIY electric skateboard the other day and after a while of testing, it started to cut in and out, I hopped off the board immediately. I thought it was just running low on battery but the issue was much larger than that.
The electronics on the board:
-10s 5Ah lipo battery
-45a 10s BMS
2x Maytech Vecs
2x Maytech hub motors.
I am using the classic “key” design (A xt60 plug that shorts the positive wire to complete the circuit - if that makes sense) to turn off and on the board. After recharging the board, I went to plug in the “key”. It sparks every time I plug it in, however this time, it didn’t spark. This concerned me.
I span the motors to see if it still worked. They both span up fine for one second then the power cut then VESCs blink red about 5 times. This happens every time I try to use the motors and has nothing to do with a broken remote as the motors only span for a second using the BLDC tool.
I typed “faults” into the terminal on the BLDC tool and this came up:
Fault : FAULT_CODE_UNDER_VOLTAGE
Current : -0.2
Current filtered : 0.4
Voltage : 7.88
Duty : 0.49
RPM : 4718.0
Tacho : 165
Cycles running : 4345
TIM duty : 3895
TIM val samp : 1960
TIM current samp : 5937
TIM top : 7955
Comm step : 6
Temperature : 31.08
I’ve checked all of my solder joints on my board they all seem fine.
These are two brand new VECS’s which makes me really annoyed with Maytech, as I have not had good experience with them.
Pls isolate your cells dude!
Sooner or later you´re gonna have magic smoke comming out that deck!
Lipos like it best in a soft environment, not wiggeling around like that.
Also your wiring confuses me a bit with that bms. In your picture, you´ve connected the top two contacts together?
