oh hot glue is just fine
i solder my battery connections through hot glue sometimes
Wait I can hit glue the make xt90 to the cord
I didnât mean to say make
lol NO
you need to solder.
Solder the hot glue!
NOOOOOOOO
solder the wire with solder. put a bit of hot glue over to reinforce the solder
That last sentence didnât make sense for some reason it never types what I typed
Told you I am stupid
Iâm dead
Shouldnât be a problem if you have a decent soldering iron
I am really struggling with the soldering, do you guys know where I could buy something already connected like this?
hobbyking
10 chars
and use 2 of theese
you would need to find one which is xt90 female to xt60 male
It may help if you use a little longer wire. Then you will be able to bend the wires more easily. Also remember using flux if you aint already
lead-free solder is a nightmare
Donât. Keep trying, youâll learn nothing from buying one. Use a longer wires. Also make sure your iron is hot enough. By the looks of it, it isnât. I suggest investing in a good iron around 60W.
Let me know if you need any help.
Make sure you âpre-tinâ the xt-90 before you try connecting the wires to it. Just hold the soldering iron inside the xt-90s metal part for say 10-20 seconds then start dipping some solder down into there (assuming solder with flux otherwise put a dab of the flux in there before trying to stick the solder to the connector). If both the connector and the wire have a good glob of solder on there then itâs a lot easier to get both globs to go molten and fuse together, if you donât pre-tin both things this is much harder.
Ok thanks for the advice
