Yes to buying a new xt90, did you use flux while soldering?
I have a confession to makeā¦
iāve never used flux in my life
Lol. Ignore what he said. Use flux
Yeah I was going to solder it first and than heat it back up an solder the cord in
No, so I need to use it
put the other connector together, see if they still fit. if they do, youāre in luck. the nylon housing is just a bit burnt. be careful when your soldering though.
What should I do about the solder that is steady in that port
melt it?
your supposed to tin those beforehand, like you were doing. just leave your soldering iron on it for a good long time until it becomes totally liquid. stick the wire in, heat the wire until the solder on the wire and in the pin turn liquid, remove soldering iron.
I found for me itās easier to have something like a vise hold the connector then put a clean wire in the back of the clean plug heat them up together and then add the solder flux does help but I always use rosin core solder.
I donāt rhink it will work because the pin broke I think
please say you used rosin core solder
i do use rosin core yes lol
i have a nice big syringe full of flux, just never use it
thatās good i donāt even have solid flux, rosin flux for days
soldered a bunch of connections with lead free matchstick solder
they were rock solid.
if it works, it works but no shiny finish
how did the pin break? pics?
It broke off the xt90 canāt take pics rn
I know Iām about to sound really dumb but can I got glue it on lol
what kind of glue? and where?
iāve soldered superglue before. the fumes burn the shit outta your eyes, donāt recommend it lol
Hot glue ten chars
