I want to build my own esk8 but im thinking of some changes.
Which motor is the best? I want a top speed of 20-22mph and good torque. And what size of the pulleys and the wheels do i need?
To this i will use 12 single cell batteries
A car ESC
And this charger
So will i be able to make a good esk8 with this setup (SK3 motor)
what else do i need to make the board complete, the links on instructables doesent work!
Mostly your plan looks ok, other than the motor and battery. A 5055 motor is really small, very little torque. I sue 6355’s and bigger. 12 individual lipos is going to be hard to fit on the deck. Maybe x4 3s or x3 4s would be easier.
Yeah, I saw that build and was impressed, but its tight, I mean really tight. There is barely any room for the electrics.
I have never used a 6374, I assume there is more available torque and generates less heat. But I’ve never needed it, my 6355’s run great. If you are doing a single motor build I would go ahead and get the bigger motor, it cant hurt.
As far as the battery is concerned, the only advantage to using multiple cells is AMP delivery. You can get A better C raiting “AMP delivery” by using x6 Turnigy 5000mAh 2S 30C Lipo Pack. There are lots of people that say 10c & 20c lipos are pretty bland, 30c will give you some real torque.
I don’t fully understand how you will balance charge a 12s battery with a 6s charger.
About the C rating, @mmaner is correct, Lipos need plenty of vitamin C to keep them from getting sick.
In my opinion, 30C should be considered the minimum.
I have run 25C Lipos at 12s and it was ok but pretty saggy.
I’m currently running 60/120C Lipos at 10s and even those sag a little. But not nearly as much as the 25C.
Sorry, my bad…im a complete rookie when it comes to electronics, im doing 6s2p… A friend of mine is gonna help me put it all together.
I just need to figure out what kind of motor, batteries, wheels and pulleys im gonna use. Should i go for a 6374? 200kv or more?
No matter how much i read i just get more confused =(
I just finished a build with that EXACT motor. I mean I am only doing initial test runs with it but it definitely reaches 20mph if not higher with a 6s setup. I am also not using a VESC but rather a trackstar 150A ESC and I have to say I am very impressed. I was very worried it wasn’t going to be very fast after I had such a small budget but this thing slays! I cannot really speak for how long it will last given these are not the “best” electronics on the market. But it works. And it works well.
This is what I think I will get
Motor:
Mount/Pulley/Belt (15 mm belt I think):
Wheels:
ESC:
diy-electric-skateboard-kits-parts/vesc-the-best-electric-skateboard-esc/
Battery 2 pcs(?):
Remote/Controller:
diy-electric-skateboard-kits-parts/torqueboards-2-4ghz-nano-remote-controller/
What do you guys think? Im really unsure about the batteries and motor.
I don’t have a clue about what else to get when it comes to batteries but I’m pretty sure that Alien or Torque motor would be what i would buy instead (if I would get something else).
I might need some new risers to prevent wheel bite as well…
