First Build could use a little help
So I have a layout of how I am going to do my board but I’m not sure how to do the batteries in series with the two vescx. Any help would be greatly appreciated.
Batteries in series, vesc-x in parallel. Then, it’s just red to red, black to black.
Ok I was trying to figure out how I would make the battery series connect to the 2 vescx and where would I put an antispark plug in the sequence
Like this
But I’d recommend putting the loop key in the positive wire, not the negative.
If you don’t have a BMS, just ignore it and take all three black wires that go to it, and connect them together.
