Don’t know hot to do the PSU wiring tho
There’s a bunch of lipo wiring posts on here. You should be able to find info easily. Start here,
http://www.electric-skateboard.builders/search?q=lipo%20wiring%20diagram
I know how to wire. Don’t know how to wire the PSU in specific.
I’m not sure what you’re asking. Wiring diagrams on here should include all you need to get a board setup with charging.
What @JdogAwesome said was a good idea. But I was looking for that PSU and don’t know how to wire it to de circuit.
Theres some other people who have asked about that and you can look them up, but its not to hard. Pretty much with most BMS you just connect the - of the PSU to the input charge on the BMS and the + of the PSU straight to the battery. then you set the PSU to 50.2V which is the full charge voltage of a 12S LiPo and when the BMS sense the battery’s are full it will stop accepting a charge.
But I’ld like to make something more clean. With a conector. Can you post a link or a photo of the PSU that you use?
Number 2 pin on the socket goes to the BMS discharge out put and the Number 1 pin goes directly to the positive of the cell pack. LEave the third one alone.
