Hi Esk8 world,
This is my first build and first skateboard. I have a lot of experience with RC planes/quads and when I learned about the DIY esk8 world I knew I had to build one. My friend has a boosted board and I wanted something that would at least match it in speed and range. I chose the monoprice hard case for my enclosures because they are cheap, durable and easy to open frequently. I chose to mount them with 1.25" skate hardware to keep things simple and strong. I have had good experience with the Turnigy Graphene batteries in RC so I chose to use them on this build. After careful checking of the battery dimensions I found the 4000mah 5s 65c battery to be the perfect fit for the monoprice case. Two of them fit like a glove in the case with just enough room for the series harness.
Jet Vulcan Classic 35: https://www.muirskate.com/longboard/decks/71839/jet-vulcan-classic-35-longboard-skateboard-deck-w-grip Monoprice Hard Case: https://www.amazon.com/Monoprice-Weatherproof-Hard-Case-Customizable/dp/B00SSF7MQO/ref=sr_1_1_sspa?ie=UTF8&qid=1511729939&sr=8-1-spons&keywords=monoprice+hard+case&psc=1 Torqueboards 218mm Trucks: collections/dual-motor-mechanical-kit/products/dual-motor-mechanical-kit Orangatang Nipples Bushings: https://www.muirskate.com/longboard/bushings/9561/orangatang-nipples-longboard-skateboard-bushings-pack-with-washers Battery Indicator: https://www.amazon.com/gp/product/B01LQ7MT4K/ref=oh_aui_detailpage_o08_s02?ie=UTF8&psc=1Turnigy Graphene 4000mAh 5s1p 65c battery: https://hobbyking.com/en_us/turnigy-graphene-4000mah-5s1p-65c.html?___store=en_us 1.75" Stainless hardware for use with 1/2" risers: https://www.amazon.com/gp/product/B073HGD9XX/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 Nano-X Controller: http://www.enertionboards.com/electric-skateboard-parts/nano-x-enertion-2-4ghz-controller/ FOCBox ESC: http://www.enertionboards.com/electric-skateboard-parts/FOCBOX-programmable-brushless-motor-controller/ 1/2" Risers: https://www.muirskate.com/longboard/risers/1903/0-5-khiro-flat-hard-risers
Updates to come
