First build! need some help
hey guys! I bought everything I need for an esk8 build except the xt 90 anti spark thingy. Do you just solder a wire that connects the end of the loop key?
Also, there’s a shorting plug on ebay, I was wondering if that can act as a loop key.
You can’t use that one you need the XT90S for the anti-spark functionality, and yes it can be just a wire loop
http://www.electric-skateboard.builders/t/how-to-anti-spark-xt-90-loop-key/204?u=decdog
Can I just loop one of these ?
https://m.ebay.com/itm/-NEW-A-Pair-of-Amass-Anti-Spark-XT90-S-Plug-Connector-Male-Female-Set-With-12AW/263374200663
Yes! 10 chars
I have another question I see people using xt60 battery harness then use a xt60 to 90 adapter for the anti spark/loop key Can I use a xt90 battery harness since I have a extra batteries to xt90 adapter Also it is more convenient since the vesc has a xt 90 connector It should work right ?
Also does the end that you plug the loop key in matter
