Good idea i had no idea that was how the range on the board worked. I was looking for around 12-20 I know I will Probobly not use that much range but it would be nice to have. Thanks
I should really go for the hobbyking motormount instead of the ebay mount.
I got the ebay mount and it broke after a month then I got a new one and again it broke.
I got the hobbyking mount and it’s so much better and very cheap! Fits perfectly on the sk3 motor.
For the pulley kit I should buy these, they fit on flywheel clones: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F182618936000
Hey bud, how are you getting on with your build? I’d like to join you in building my first board - perhaps we can di it together? What does your parts list look like so far?
Sure, I would sugest what I have on my first post as most of your parts, I would go with the hobbyking motor mount and a gear train kit instead of my motor mount and gear train kit from ebay. I would also get a larger battery if you want more power from your motor, and more range to rude your board.
yeah your better off spending more money with the charger as E1Allen said it takes time and depending on what power adapter you get it could take even more time.
You can definitely use your own board. If your trucks are a weird shape you might need to cut them or file them to fit a motor mount but you can definitely reuse your old board. That is one of the cool parts of making a board yourself
If you’ve got decent enough trucks you can make your own mount and weld it/have it welded to the trucks. I did mine with a drill press and some files, and had it welded by a local guy in his garage. Cost me $15 for the sheet metal and $30 for the weld.
