Weight: 225lb
Build Deck: ($50) Generic no brand, preferred: drop through with 8 plys source Trucks + Wheels: ($45) 90mm flywheel clone w/ generic 180mm trucks source Motor: ($80) Turnigy SK3 6374-192kv source ESC: (~$100) VESC 4.12 source or VESC 5.0 when it’s released Battery: (~$200) (including accessories)10s2p Basen 26650 build + buy Mount + pulley: ($117) DIY TorqueBoard v4 kit with pulleys and belt source Enclosure: ($65) Psychotiller Low Pro source Remote: ($40) Mini remote source
COST: $697 WITHOUT SHIPPING! YIKES!
Notes Motor will be mounted heel side regular stance. Thinking about reverse mounting. Gearing ratios: 16:36 probably (2.25 ratio), 16:40 (2.5 ratio) possible with 3D print source Might want to try custom GT2B enclosure source, not very cost practical, might just go with cheaper mini remote Might 3D print a battery+esc enclosure or Fiberglass a custom enclosure. Love the natural wood look, thinking about just using spray on grit instead of grip tape. Not sure how VESC is programmed, need more research. Be sure to tune brakes carefully, big reason people get hurt. Don’t build for speed, let’s not get hurt, 15-20mph seems plenty fast. Try and incorporate a deadman’s switch along with beginner/normal/maxvoltage modes.
