Do you think your drive belt protection can be placed on a normal diyelectricskateboards.com’s motor mount / pulley system with their 5055 motor? If so, would you please want to send me the 3D-design of the printed piece?
@SyrusB
Yep, charge each cell by itself. I need a bigger PSU to do parallel charging. Takes about an hour per cell. Not a big deal TBH.
@Decdog
Can confirm, this battery indicator is 100% garbage. On my second one already. Need to find an alternative.
@Daan_vZon
Maybe? I don’t know how that mount looks. Is there a CAD file out there for it?
@Smorto
Yep. I wanted the % facing up so I could have a rough gauge of remaining battery life. The one embedded in the housing below was just for reference. Battery remaining isn’t linear, so I wanted to easily collect some data points relating % remaining and voltage.
@Print3r
Thanks! It does a little more than that. There are standoffs embedded in the print so that the external guard reinforces the motor mount. The first mount that I cut bent under stress.
Went for a ride last night in Ocean City, NJ. Calm before the storm - this road will be insane in 2 weeks. But they’re doing a lot of paving right now, so some streets are smooth AF. Gotta get out there and carve them up while I can!
