@torqueboards Nice motors. Like what I see on your website.
I have a similar question. Have you tested the motors with 80mm/90mm wheels? What is the smallest wheel diameter you would recommend?
anything above 70mm probably. the smaller the diameter, the smaller ground clearance your motors will have and the higher odds of being broken
@torqueboards great product
This weekend has been more expensive on the wallet than I had imagined on Thursday morning !
Nice job Dexter! I’m glad to see you step the motor size up and make it super beefy.
I’m excited to race these with hummies hub. I think they will be close to hummie hubs, just not sure which way it will go haha.
Hope you can get some to the hill for the uphill race in January!
We are using N42SH magnets. We haven’t had any issues with heating. Trying to get more out there in the wild so we can do more testing but there’s a ton of cooling so I doubt it would be a problem. We had 2-3 different hub motor versions which we’ve tested in the past. I’d like to think I’ve checked everything off as far as having any heating issues but always room for improvement.
90mm’s would do great… 80mm would be cutting it short. Probably wouldn’t use 80mm.
Should be fine. I’m sure, you’ve seen short boards with a 218mm Truck.
With wheels on our DD setup is only about 10-15mm wider than our 218mm setup. It’s barely noticeable.
Should be interesting.
Torque D-Drive + Hummie Deck What do you think ? Good combo ? Enough clearance ? Let me know your thoughts. thanks
Top mount would be fine. Drop through the motors would probably foul on the deck.
Top mounting the hummie deck will be not too flexy ?
Specially for an AWD set up ?
Top mounting shouldn’t affect the flex?
Anybody wanna share a 4wd order? Lol I’ve got sr trucks for the front
You ordered 2 drives?
I wish… I was thinking if i ordered a 4wd with someone we would both have 2wd kits just without front trucks, save a little $$. Lol
I’ve been waiting for these to come out since I joined the site. this is actually the first thread i bookmarked and followed. I had some money saved up for when they came out but this injury is making me feel guilty about spending it. I really want them tho
Thats easy, skip the surgery and let your arm atrophy and rot away. A man has to have priorities
Just go on disability lol, because I sure as hell can’t do either one of my jobs with one arm. I can still build and ride tho
I have ordered the 4wd 90kv and would consider doing this.
@F.Taylor Send me a pm and let me know what you’re thinking. I just realized that it ends on cyber Monday not on the 1st like the raptor pre order… Balls
