I have well over 4000 miles on this type of battery pack and it is still holding up. Most builders go wrong by not stabilizing everything inside their enclosure with a dampening material like natural cure silicone. My guess would be that you had excessive movement or you did not fix the buss bar from moving. Batteries should always be 100% secure. Any movement at all will eventually wear through the battery casing over time due to vibration.
I lay down strips of foam rubber and lay beads of silicone to fasten the pack inside my decks. A second set of strips go on top of my packs to allow for a compression fit once the hatch is on.
@trigger4point7 the batteries are like little flares when they go thermal, the whole point of this is to stop that from being a possibility or at the very least limit the extent of the damage if the board is compromised by an accident. If you are worried about the adhesive flaring up just be sure to buy from a reputable distributor and stay away from Alibaba for your insulators.
A fuckload of flex. I could pot an entire sled in silicone and if i arancged things correctly i could mount it on a loaded deck and bounce around all day.
the problem is that silicone is soft so a damage and puncture resistant shell is still needed, but no reason it couldn’t be scaled like armor to allow flex.
shit that sounds like an idea there. If you properly footed the silicone into the deck you probably wouldn’t even need fasteners of any kind, just clever ridges and etchings to give it some grab.
I’ve been using silicone to pot the packs into the fiberglass boxes for about a year now and it has eliminated all issues concerning vibrational damage and wear on packs.
@Rinzler tested the narrow nickle strips as fuses like you mentioned earlier in the thread. They basically turn into space heaters without breaking connection, I wouldn’t use them.
Yeah that whole thing seemed sketch to me. i’d rather use a thin gauge superworm because i’ve seen what happens when those smaller wires, 22 guage and below, do when they wick up inside that silicone sheathing during a hard short on an 18650 pack. It’s awesome to watch. You can see the light from the melting copper travel up through the center of the silicone tube and then nothing. MEanwhile, the insulation is 100% in tact and the wire looks as if nothing has happened to it at all. The fire was completely contained, so to speak. Burned up copper safely inside the silicone sheathing.
what gauge do you think would be appropriate if we tried that as a fusing technique?
I wouldn’t use a multistrand wire for a fuse. I do use a small section of 12awg silicone sheathed wire to make my series connections. The short length, 1.5", makes the 12 awg overkill but it is good for the peak currents. Longer runs necessitate the use of 10 awg from the battery main terminals.
In my opinion .15mm is not thick enough to carry the load, I use .015 inch thick buss bars. You can spot weld onto the buss bar using the thinner nickle.
Yea I’ve gone with a new design for my new board where I’ve used your original cell level fuse design as inspiration. My packs are two cells thick so I run the bus bars on the side.
One of the things that’s made designing my packs more difficult is that I wanted them to be able to be easily removable from the enclosures and split up into sub 99Wh packs which makes securing them more difficult.
Atm I have the batteries wrapped in kapton tape, then a thin layer of felt for vibration dampening and then shrink wrapped and stuck to my enclosure with velcro. They didn’t come out as cleanly as I’d liked, but so far they’re holding up really well but I guess we’ll see how things go.
Fair point. Interesting to note that it seems to be a fairly common practice on these forums.
This being a larger 10S6P pack, I don’t think I really push these cells particularly hard though so shouldn’t be an issue
I think it looks sexy that’s the only reason I use it plus a little bit around certain areas can be for strictural integrity, but too much and it builds up heat
It’s advantage is that it’s heat resistant and non conductive, compared to fish paper non exactly sure, I have both along with the obligatory heat shrink and glass fibre tape
Also heat resistant but stronger than all the others, tends to be thin like 1-2cm and used to fit structural integrity of the pack in the applications I’ve seen
i glue my cells, use electrical tape to bind the wires down and prevent balance leads from rubbing against nickel, and then heat shrink the whole thing. I don’t use kapton. just in case anyone was wondering.
I’m still looking to have custom nickel or copper stamped though. I may even try to machine out a few myself once i get Shirley leveled again and rig up a jig with an engraver bit.
I want to do cell level fusing not only for the safety of potentially preventing thermal runaway and over current discharge, but also because if done right the process can can take a lot less time than welding.
