They say that the 12 inch trucks will fit a 6355 or 6368. I want to fit 6374 motors. Do they fit, can I space things to fit? They say only d shaped shaft pulley as well. I have a dremel. Can I make it work?
Yep. What mounts do you have? Have you had the minimum amount of liquid courage to make such adjustments?
Which mounts…
I would try to avoid dremeling your motor shatf if at all possible. Magnet+shaft shavings which you will have,is bad news. Even if you tape it off and it will find a way to make your life hell. Andway, what motors do you have?
