Brand new Dual 6.6, got the usb1 to work in normal and FOC mode but the second side never got read. If I plug the usb into the second port i cant get connection.
tried installing some driver that was mentioned in another thread, no luck.
They’re connected with can theres a small switch in the middle between the usb’s. I think both motors should set up at the same time
switch was already on
yeah that’s the switch. if you try to run the VESC tool both motors should turn well i think
Yea the usb2 is shot wasn’t even receiving power
