Now I wanted to make a new motor detection but It doesn’t work. The motor isn’t able to spin. The reason is that the focbox means that the actual “T Motor” value is about 180 degrees, Is there a function to reset or calibrate that value?
I already unplugged the sensor plug but it still shows something like 179 degrees.
When I’m back home I will try to upload another firmware and hope that this doesn’t show up again.
Or Could it be a hardware failure?
Could I disable the over temp. Function?
And are somewhere here some schematics about the focbox available?
It seems like you did everything right maybe besides messing up the bootloader the first time. Why did you have to reload the bootloader what did you do the first time?
A couple weeks ago, the last time it was alright, I was on a ride and while that it stopped and the ackmaniac app shows that abnormal motor temperature.
Then I went back home and wanted to reset the as because I thought that a bad sensor wire was the fault. And in that trouble I did something wrong while installing the new firmware and the bootloader was corrupted. So that happens first while riding
Now I made a mistake.
I got a short between the temp wire and the 5v. Now the LEDs are out and I can’t connect the ESC anymore…
If I try to turn it on the Board U2 gets got. It’s an GH12E, an voltage regulator for 3,3 Volts.
I could solder a new one but do you think that’s the only broken part?
Does anyone has schematics for the focbox?
