This question is geared towards the regular Focbox and not the Unity.
I was wondering what is the difference between the revision numbers, ie v1.6 and v1.7?
The design files that used to be released are for v1.3. So wondering what exactly has changed?
It was mentioned somewhere, on a side note that do not disconnect CAN Bus if both ESCs are powered on? I use CANH and CANL connections by the way.
Ah very good to know, thanks! Unfortunately I have v1.6 revision.
I don’t get how CAN Bus breaks things on the ESC from a simple disconnect? Wondering if other VESC brands have this issue as I didn’t know about this.
To bad Enertion and others do not provide a detailed changelog and such with new revisions…isn’t that required for open source projects?
