It says firmware 46
410,411,412 is the file you need.
In the red field you will see the actual version installed on the vesc if you connected.
It wouldn’t allow me to download it, it kept redirecting me to 46
Than you have the wrong fw installed properly.
If you have one vesc with the right fw you could use the newest vesc tool and flash the right fw via CAN.
If no than you will probably need an st v2 link.
I have no clue how that firmware was downloaded, i never even played with the firmware
How would I get that st v2 link
Amazon 8$. Just search for stl v2.
Didn’t you said it was working before when you got it from an other user? Maybe he knows how the wrong fw came on it?
Yeah, he told me it was working and when I came to do motor detection, it somehow downloaded the firmware unless I accidentally flashed it without knowing better. It’s all @Boardnamics fault, I asked him to run motor detection and he probably flashed 46 since he has the trampa vesc😭
but trampa is hw6 so it would be wrong either way.
You don’t have a second vesc laying around you could use to flash the right fw?
My second esc is fried😂
I would like to assist you over teamviewer, I think I am able to solve it
Not sure what team viewer is
It’s a software which allows remote access
If you are using a Windows PC then I can do it right now
Let me download it on my laptop
Windows on my laptop, my pc is currently broken
Downloaded it
I have an ID and password, I need your ID
