Im trying to help my brother after he used countless hours trying to figure this out. Thought i had an idea and used older posts, but unfortunately nothing wanna work as intended.
The problem is the focbox is not seen by the vesc-tool…
So i read and read and people seemed to use a stlink to upload new bootloader or firmware. It would not allow me to do so.
“unable to run verification”
You probably already saw the post from 2018, but did you try this?
Step 1: Right click on start menu and select device manager
Step 2: Go to Ports (COM & LPT)
Step 3: Delete all COM Drivers by right clicking on each one and selecting uninstall
Step 4: Restart Your System and Open Device Manager again to see Which COM ports appears (because some of the systems has multiple attachments attached that’s why multiple COM ports might appear)
