Hello i’am Manu, I live in France and get my 2nd project the FORAKER (http://www.e-sk8.fr/forum/viewtopic.php?f=29&t=2235)a MTB based on a hollypro 35, dual engine OVERION, 12 s 12000 mAh lipo, mount OKP. Unlike my first Board the Hulk Board http://www.e-sk8.fr/forum/viewtopic.php?f=7&t=1123made from A to Z this project is based on that of Pimousse. Here are some pictures:
Magnifique M@nu
Vivement les v6, ça va être royal !!!
![:wink: :wink:](https://electric-skateboard.builders/images/emoji/twitter/wink.png?v=9)
![:cry: :cry:](https://electric-skateboard.builders/images/emoji/twitter/cry.png?v=9)
What happened with the Lipo Charger? Never heard that one grilled.
Nice build in general, good to see more people on the VESC 6/Overion 130kv/12s12Ah team
Thanks @Der6FingerJo I put my battery graphene turnigy 6 s 12 Ah in storage mode on my DIAMOND POWERHOUSE and at the beginning of the process for the 2nd battery … 2 mosfet grilled …
Hmm weird. I can only recommend my trusty ISDT charger but i’m sure the diamond stuff is also good quality.
Smart Ring by @Pimousse it’s operationnel, big up to @Pimousse and @stewii for taking the time to solve my SR compatibility problem with ESCApe.
Manu39 -
Very nice and powerful could you tell me where you got your chain drive componets? I am looking to mount a chain on my MBS wheels.
Thanks,
Kevin
Thank you does the kit include the MBS mounting bolts for the Sprocket to wheel? and offset hardware?
Normally yes the kit includes crown / pinion / chain / spacer and screw. Ask Yann of OVERION by email, he is very reactive and good adviser.
Thanks will do…
Mount Foraker is a large mountain in the center of the Alaska Range that rises up to 5,304 meters, in the Denali National Park and Reserve, 23 kilometers southwest of Denali. It is the second highest peak in the Alaska Range, and the third highest peak in the United States.
here is the video of what was initially a test autonomy ended in crash test …
Seems like a small pothole upset your balance causing the larger imbalance?
The Trampa looks quite flexy, what ply are you using? Maybe a stiffen bridge would help with that and you just ride through
Good camera work!
thank you for the video compliments, for the board I use a 16 ply, I just tighteners trucks … can be red dampa instead of green …
